Gents,
I was in the process of doing some work tracking down a possible ignition switch problem (my thread on that is "kill wire question") when I went to start the motor with one of the two blk/yel wires from the PP unpluged. As I was trying to start the engine I heard a buzzing noise, when it had just worked moments before. I plugged the blk/yel wire in and it still only buzzed. When I had someone else crank on the igniton, I felt the buzzing noise coming from the starting solenoid.
I used my dremel with wire brush and did all of my contacts on solenoid, starter etc..and there tight.
Battery is 12.7V
POS stud on Starter Solenoid is 12.6V
I checked the 20 amp fuse and replaced it..as whatever I did popped it. Still only buzzing/clicking.
I bypassed the solenoid and the starter turned the motor fine. I also noticed intermittent T&T issues...one minute it works the next it only makes the relays buzz.
Did I screw something expensive up? I'd appreciate to hear your thoughts.
Thanks
D1
Battery is 12.7V
Thanks
D1
