joemamma_222
Thread starter- Joined
- Jun 23, 2003
- 201
Hey all was out with a buddy last night trying to figure out his overheating prob. Last week he was on the lake and noticed an overheating problem so when he got it home we changed the thermostat and impeller. After changing we hooked up the Muffs and plugged the hole in the leg and noticed we werent getting any water into the system. I told him these 270 legs dont cool real well on muffs. So Figuring the Lines has no water in them and they needed "primed" with raw water we filled a barrel and lowered the leg into it started the motor and still the impeller was not Drawing the water in. We unhooked the raw water "IN" line from the Stainless tube and put a hose directly into it. Wala the motor was cooling. Then we took th hose and ran water down the stainless tube to the leg (thinking we mighta had a blockage) the water was flowing out the vents in the LU and all seemed fine untill I plugged the vents with my hand and I did notice water comming from the middle of the leg where the pickup tube runs up about midway where the LU swivels. Anyway we took it to the lake anyway and the motor cools great at Idle but when on plane it'll peg the Temp gauge real quick. Is that pickup tube supposed to be completely Air/water tight ? Or do we have a water pump issue ? I was thinking it might be sucking air when we are on plane and the pivot point is up outta the water. Anyone had this issue before ?
Sorry for the long winded But I wanted to let yall know what we've done so far...
Thanks !
Joe in Ohio
Thanks !
Joe in Ohio
