Boatonbrain
- Joined
- Apr 26, 2008
- 10
I'm replacing the impeller on my water pump (first time) and have a problem getting it and the baseplate off the drive shaft. The motor is a Evinrude 1988 50 hp tiller. I have a manual but it does not cover this issue. Right under the gear on the top end of the drive shaft is a ring that is slightly larger in diameter than the shaft. The impeller and plate will not slide off.
Obviously the existing impeller got on the shaft so my question is should I be forcing this issue or is there a way to get the ring off?
Any help will be appreciated.
