CATransplant
Thread starter- Joined
- Feb 26, 2005
- 6,319
OK, I'm working on a design for a device that will attach to my 1992 Johnson 6hp that will allow a hose connection. It won't be difficult for that engine, and I plan to post drawings and instructions for others to make one, as well.
But...I have a question for owners of 6hp motors from the 60s, 70s, and 80s:
On the '92, the intake screen in the water outlet tubing extends up past the cavitation plate, and there's another opening above the plate that can also allow water in to the cooling system.
Is this true on the earlier 6hp models? If you have one, please take a look at it and let me know. Also, what is the length of the long side of that water intake and exit tube on your outboard, from the cavitation plate to the tip of the tube.
If possible, I'd like to design this to be useful on multiple models. If they all have an intake above the plate, as well as below the plate, I can design it so that the device blocks the lower intake and puts the water in the upper. If not, I'll design it the other way, putting the water in the lower intake.
Finally, if you can snap a photo of the upper intake, if it exists on your earlier model, it will help me with the design.
I may sell these, but I'm going to give away the design drawings and instructions here, so thanks for all your help. Sadly, the parts diagrams on the BRP site aren't detailed enough for me to see this. The later models use a combination screen and plug, while the older ones have a separate plug, and I can't see the correct side of the housing.
