steve hughes
Thread starter- Joined
- Aug 12, 2005
- 3
165 HP 3.7L (2 BBL) Mercury 224 3.7L 1988
BACKGROUND: Last season this engine lost coolant regularly.
I would replace at each use and kept close watch to avoid overheating. Observed some leaking (steam and odor) at exhaust manifold at start up. Suspected a bad exhaust manifold to head gasket and/or elbow/resevoir to manifold gasket.
Went to replace the exhaust manifold to head gasket first. Took the opportinuty to replace spark plugs as there was evidence of rusting at interface of spark plug and the head at cylinders 3 & 4 and coinciding with the observed leaking area. Found and removed 2-3 ounces coolant in cylinder 4. All other cylinders were dry.
I've now removed exhaust manifold and elbow/resevoir from boat. And have seperated the elbow/resevoir from the exhaust manifold. There is evidence coolant crystals in all exhaust ports of the manifold.
There appears to be several areas of failure that could explain the conditions, and observations above.
QUESTION(s): What are my next steps in solving this? How can I determine how the coolant got into the cylinder?
Thanks, Great forum here. I've learned much about this engine. By the way I have two of these in a twin set-up. Who could be so lucky!!!!
