1984 90hp yamaha only running on 2 cylinders
seahawk108
my 1985 90 yamaha when cold runs fine when it warms up only fires on 2 top cylinders. she wants to fire occasionally on the bottom cylinder, i have swapped coils with #2 cylinder with no change in the third, #2 still fires fine #3 still not firing properly. took carb cleaner and sprayed in one cylinder at a time choked down when sprayed into #1 & #2 made no difference when sprayed into #3. anyone have any answers please help. thanks seahawk108
rodbolt
Re: 1984 90hp yamaha only running on 2 cylinders
check the CDI output on #3, will take a DVA meter, also check the pulser coils and high speed charge coil output, if all tests pass but the CDI output you may have a bad one,
that system uses a pulser coil on 2 and 1 but 3 is "synthesised" by the CDI.
seahawk108
what do you mean by dva meter or did you dca (dc ampmeter) thanks seahaw108
rodbolt
most digital meters are averaging meters with a built in display delay, peak reading meters have the movement set up to show voltage peaks, thats why most Digital meters need a DVA adapter to display peak voltage.Digital Voltmeter Adapter.
peak reading meters are allmost always analog, I used some specialty stuff in the USN but its rather costly for a shop thats not paid for with taxpayer dollars :)
seahawk108
robolt i have a dva adapter coming for my multimeter. where can i find instructions on how to check the cdi and pulser coil and what the readings should be. thanks seahawk108
rodbolt
tune up spec guide has it, stator output low speed, Br+ lead,Blue negative lead, 85V cranking loaded and 75V at 1500 RPM loaded, high speed, +lead on the red, negative lead on the blue. 45v loaded cranking and 155v at 1500.
puler coilw/r+ lead-w/y and w/b(+)-w/r 2.5V loaded cranking and 7 v at 1500.
