Gas Powered Boat At Trawler Speed
Reel Poor
Re: Gas Powered Boat At Trawler Speed
If the drive system is geared and propped properly it's no harder on the engines than it would be in a smaller boat. As long as the engines can reach maximum rpm's they will be fine. What will take a beating is your wallet. :eek:
Fishermark
In addition to "hard", you need to define "trawler speed." I would take that to mean slow as opposed WOT. If that's what you mean, it should be easier on the wallet. ;)
Mischief Managed
Gas engines will last a really long time with a light load. The lighter the load, the better, so running a planing hull at displacement speed can make the engines run a long time. If the boat has stern drives, low speeds will tend to pound out the grease in the coupler more quickly than high speeds. Halve the coupler grease schedule if you run low speeds with a stern drive.
Diesels last longer at heavy loads, like 70 to 80 percent of their maximum rated output power, otherwise they don't run hot enough.
arks
Is it hard on gas motors to run at trawler speed with a 38' twin screw?
I sure hope not because that's EXACTLY how I'm running this year!
