AnglersEdgeNY
Thread starter- Joined
- Oct 13, 2007
- 34
I have no spark on all 6 cylinders. After reading the manual and reading posts on this site here are the tests and results
All plugs removed, spark tester set to 7/16" gap, red plug disconnected, jumped the starter- no spark
Disconnected the black/yellow wire connector to each power pack- No Spark
Sensor coil ohm readings were 42 +/-
The only reading that was not within specs was on the starboard side B terminal to the D terminal. I got a reading of 0.
The charge coil ohm reading was 790.
Below the 970 spec'd in the manual.
The charge coil output is 140.
Tested both power packs as per the manual and both showed no output.
All the ignition coil were within the ohms specified.
New battery, new plugs, all connections cleaned.
What are the chances of both power packs being no good?
Am I on the right track.
Thanks in advance
Mike
Thanks in advance
Mike
