OD Ratio Change
starsnstripers
1970 MC-1 250 cid 165hp L-6, OD raitio 1.65:1 I just aquired a boat with a mercruiser 120 4cyl. I'm assuming it's ratio is 1.98:1 is it possible to run this drive on my 165 without changing the gears or? possibly reprop? It says 120 on the drive so alpha 1 maybe havent got the #s or yr yet. looks like mid 80s, thanks.
Re: OD Ratio Change
Ayuh,......
Maybe,... If you can find a prop Big enough......
starsnstripers
Re: OD Ratio Change
Well i guess its a MC-1 it has the eye on top the serial # is 5162162, can the yr be figured from this #? thanks bondo maybe a 23p prop? It also has the trim senders on the hinge pins istead of the top of the bellhousing. thanks
Re: OD Ratio Change
Ayuh,....... Just a later model of the older drives,.......
Maybe a 25",..?? :D
starsnstripers
Re: OD Ratio Change
Thanks Bondo, so it's a newer MC-1 thats good now if i could use it? haha it looks in alot better shape than my ole MC-1. How about a 4blade prop wouldn't that help me get closer to where i need to be? Whats the largest pitch you can fit on one of these drives? Dia/Pitch? thanks
Re: OD Ratio Change
Ayuh,........
It's 8" from the center of the propshaft to the Cav Plate,.....
So a 16" prop is pretty much the Most it'll swing,.....
Now Pitch,...... Seeing that a Bravo Racing prop will fit your drive,......
The Sky is the Limit,...... Or, Maybe your Checkbook is the Limit...............:D
starsnstripers
Re: OD Ratio Change
haha! My checkbook didn't like that! I'll save it for a spare and keep my eye open for a 23-25 p 15-16" prop im just sport fishing anyway not sking or tubing, not in to much of a hurry! Thanks Bondo have a good night!:D
Re: OD Ratio Change
Ayuh,....... Forget about Diameter,+ Shop for Pitch,+/or Blade design......
The Engineers will figure out the diameter.......
ziggy
Re: OD Ratio Change
just wondering, is this drive gonna be behind yer 200hp L6? if so, maybe that'll get ya closer to the proper ratio..... just wondering.....
