CMC power tilt and trim wiring??
duckhunter14
Sorry but I have another rookie question.. I just bought a tracker.. it has a 40 hp Johnson on a CMC power tilt and trim bracket.. the main control for the power tilt and trim are on the throttle handle, but up front where my trolling motor plugs in there is another set of tilt/trim control buttons.. i traced the wires to the back of the boat and they go to a round black plug.. there is a red, green, and blue wire that run all the way back and a short brown wire that comes out of the black plug and has a female (i think) clip end on it.. how can i hook these up so these controls will work also?
thank you!
HondaPower
Re: CMC power tilt and trim wiring??
Find the wires on your CMC unit that control the trim there will be three wires, Blue for the up servo, Green for the down servo and red or purple for the power. The power line should have an inline fuse holder near the power trim unit. Connect the existing wires from your front mounted switch to the wires in your CMC harness making sure your power wire is connected after the fuse holder so it will be protected by the fuse as well.
