3.0 L Mercuiser 2001 ser # 0m027691
casey33
New fuel pump , Carb rebuilt ,timing dead on , good fuel motor will not run off idle and when it does it will not run after 2500 rpm
any one have a idea
Limited-Time
Re: 3.0 L Mercuiser 2001 ser # 0m027691
When was the last complete tune up?? Have you checked the fuel filter/water separator?? If it has one.
Carb rebuilt
Ayuh,.......
By Whom,+ How Throughly,..???
It sounds like that's Where I'd be lookin'.......
Don S
Might want to recheck that SN, that number is for a 8.1L inboard, not a 3.0L IO.
Along with who/how on the carb rebuild, I would also be asking how the timing was set. A 2001 3.0L uses the Delco EST distributor and MUST be put into base timing mode in order to check timing and setting it to specs. If you just grabbed a timing light and turned the distributor, you are way off.
