gustafsonerik
Thread starter- Joined
- Jun 25, 2006
- 238
85hp 87 force
I recently replaced the ignition switch/fuel pump/switchbox..this is the problem it will start only when i put gas directly in the throat of the carbs then it will only run on full warm up throttle.. it sounds like it wants to die..I cleaned the carbs but still no avail..the idle screw on top of the carbs,how far do i put them in???? any ideas??? could i have crossed a wire in the switch box or it wouldn't start at all??? compression is 119 in all cylinders..
