imported_esoxhunter
- Joined
- Jan 14, 2007
- 21
Hi all,
I can't sleep since reluctantly taking the step of putting 2 screws into the transom of my 2003, 20' Lund Alaskan (tiller) this past weekend.
I had to install a transducer and knew that getting the location right on the first attempt was not likely. So, I decided to mount a good sized thick piece of plastic to the transom which I could then use to screw the transducer into as many times as I want without making swiss cheese out of the transom.
To attach the plastic mounting board I first drilled 2 holes right through the piece of plastic. Next, I drilled 2 holes through the transom (ugh!) using an appropriately sized drill bit for the stainless steel screws I used to mount the plastic board to the boat. I used a generous amount of GE Marine sealant (silicone?) around each screw hole on the back of the plastic board, in the holes in the boat, on the threads of the stainless steel screws that went into the transom and all over the back of the plastic mounting board.
Now, I can't sleep. It nearly killed me to drill into my otherwise virgin vessel. Now the worrying about whether or not I've done somethign I shouldn't have or did it wrong is really bothering me.
Can anyone, please, give me some thoughts on this. If I've really screwed up, I'd want to do whatever is necessary to fix it right away. On the other hand, if I have nothing to worry about, that would be nice to know too.
Please... help a brother out!
E
E
