AGENT 37
Thread starter- Joined
- Mar 2, 2007
- 319
Does anyone have a jack plate that allows the motor to be lowered below the normal height of the transom, or are they all designed to raise the motor?
I have a recently purchased 22' aluminum Bayrunner with a 24.5' transom. It has a 90 HP long shaft Honda that sits too high and has a cavitation/ventilation issue and does not allow me to utilize trim to bring the bow up out of the water because it must be run in the full trim down position. I need to get the bow out of the water because it is throwing too much water and making for a very wet ride. It blows out any time that I hit the throttle for a quick hole shot and it always blows out in a turn regardless of trim. I am curious as to the mounting bolt pattern on a fixed jack plate; would it allow for installation with existing holes in the transom at a lower level? I don't really want to drill new holes in the boat. But would have no problem making them in the jack plate if there was room. Also, would one of the hydraulic units be able to lower the outboard 2-4 inches? What is the range of travel in the down direction when mounted normally, or do they only allow for upward travel above the height of the transom? I've attached a picture. Thanks for any feed back.
Lower units are so stinking expensive, I thought about extending this motor out to 25 inches but it would cost over $2000 for new parts and I haven't been able to find any used ones for the past few weeks.
