maxum247
Thread starter- Joined
- Sep 18, 2007
- 1,363
1989 Force misses, at least I think it's a miss! This is quick and constant up to about 2000 rpm or so, tach jumps about 150 rpm each time this occurs.
I had a bad coil on 3 recently switched it out with a coil from a late 80's 85 HP Force and it started firing strong on all four cylinders. But there's this sort of miss or something that replacing the coil didn't completely fix.
When I pull each plug wire each cylinder drops everytime and the engine acts like it wants to stall, put the plug wire on and the cylinder picks back up but the engine still seems to have a miss or something. This makes me think a weak spark on a cylinder but pulling the plug wires don't seem to indicate it.
Checked all wire connections and grounds that I can think of. Changed spark plugs which were new BUXH to UL18V made no difference.Thought a CD box might have something to do with it but it seems to have good fire on all four!
Stator was replaced a while back.
Is it fuel? I'm not getting a lean pop. Seems rich if anything. I'm running best at 1 turn out on the carbs and am jetted at .101 top carb and .94 bottom carb. Tried a spare set of carbs made no difference.
Would to much oil in fuel cause this? Any help greatly appreciated! Thanks!
