beavertrapper70
- Joined
- May 2, 2008
- 14
I bought a 30 foot Kayot pontoon boat last summer, and I use it on the Muskingum River in Ohio.
Here is my problem...one of the two pontoons(larger dia. than 55 gallon drums) has several eraser size holes in the very front, where it starts to narrow into a dome. You can see the rust, and it looks a bit rotted(flaky rust). I can assume the inside is the same way, but keep in mind the pontoon is compartmentalized in 5 sections, the back three sections are air tight, the 4th has water in it but no leaks( I think there is a hole in the inner wall of the toon), and the front section is the one with holes, I was told by a friend who is a professional welder that it more than likely cant be welded. What can I do? I priced foam, it seems affordable(350$ for 40cu. feet). I was told I could buy new aluminum pontoons for about 2 grand, which isnt worth it.
I only paid 1000 bucks for the boat, with a 35 horse in great only shape, so if I cant fix the leak Ill just put the motor on another boat and scrape out the boat and trailer.
I am pretty new to boating, so any info would be appreciated.
Josh
Josh
