fuel pump kits
Benny1963
i have a 1980 evin 175 powerhwead on my 150 mid im putting the powerhead back on. want to rebuild my pumps the numbers im getting from my pumps ishop does not show rebuil kis only the pumpsthe numbers are388555,upper and 0389440 for lower. can anyone give me a lead on these rebuild kits .
these numbers posted are the pump assemblys on the 2 pump sys .
im going to the 175 powerhead andthe pumps are off of and 150 same year .
i also believe they sale a hi per pumps on some of the motors and trhought
i may need to do that going to the 175.
thank you all bennyb
Gary H NC
Re: fuel pump kits
Hi Benny, I just rebuilt mine a couple days ago.I believe we have the exact same pumps. The only difference i could see in the 2 pumps was the little round disc that pushes against the diaphram.The lower pump was larger than the disc under the spring in the upper pump.
I just test run it about an hour ago and it runs good..
Here are the kits i used..
http://bpi.ebasicpower.com/mm5/merchant.mvc?Screen=PROD&Store_Code=eBasicPower&Product_Code=GLM40820
Here is the Mallory kits,
http://www.iboats.com/mall/partfind...gd_poid=109272&gd_row=87&**********=245784844
Benny1963
Re: fuel pump kits
hio gary thanks or both of these the same just different brand are is one of them top and one bottom
thanks my pulse hose shows a spring in it do you have that on yours
they might have left that out on mine
thank you gary also you just replaced your coils didny you use cdi
if so how were they ibought a couple of sierra but not sure if iwant to get the rest in sierra or or order all cdi.
gary i still have a full rotating ***, everything is good but two lightly scuffed hole on one bank its complete heads off if you need or some one you know
may need this it would be excelleny for rebuil because all bearing are new
had 6 new brp pistons in it 030 the other 4 bores still shoe cross hatching.
its rapped up outside dont want it to ruin will hook you up iknow that
shipping is high so i will give it to ya if you find the need anyone else supercheap some coil money or something .
see ya on the forums
Benny1963
Re: fuel pump kits
hey tash ya lost me
did i go alittle far on my post with the other post alittle confused .
thanks bennyb
