1984 Omc Inboard 3.8l Cracked Block
posey
:confused::eek: my local options seem to be to replace the block. Looking at $2,500 motor for a $1900 boat. Any better way to salvage the situation?
GiMLit
Re: 1984 Omc Inboard 3.8l Cracked Block
Block cracked............. if only externally you can easily do a JBWeld repair. This is providing you do not have a closed cooling system. If you have a closed system it builds pressure which you don't have in a typical marine system and therefore a rec "jimmy fix" repair would be to have it welded.
Have you checked to see how far the damage goes????????
GiMLit
Where are you located?
Ayuh,...... What the 'ell is a 3.8l,..??
bomar76
Half of a 7.6
Bt Doctur
What about a Chevy V7
fendersfender
To answer the first question.....you can buy a reman 3.8 for about $1200....AND a 3.8L is a chevy v6 that omc used in front of a 800 series stringer drive
