Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
hi
i recently put a new prop on,i now realize that the engine was in gear when i did this. now when i try to start the boat it wont go into neutral or reverse just forward .
replacing prop due to hitting something
what am i doing wrong ?
Installing a new prop should have no affect on shifting from neutral to forward or reverse. The reason you can't shift properly is because you hit something and damaged the lower unit in addition to the prop -- not because you changed the prop.
