RPM,s
davy mcclelland
Hi,
Linked & syncd my E50rnlic recently(according to manual) & got a Tiny Tach today to help verifiy that my forward idle rmps were good at 850+ or - 25.
Neutral idle revs showed an increase up to 1100rpm.
Does this increase seem to be excessively high to you???
HighTrim
Re: RPM,s
Under load (on the water) and in gear your RPMs should be a bit lower. Are you testing on the water or in the driveway on muffs?
davy mcclelland
Re: RPM,s
OOPS... meant to say 800 +or-25 rpms......
Yes Chris, on the water unrestricted, according to manual specs. Got this reading OK, but just thought the jump up to 1100 in neutral might be a wee bit high!!!
Thanks, DAVY
Benny1963
Re: RPM,s
if your on muffs unloaded your rpms will climb quite high you need to set it in water in gear and go for 600 or so maybe 700 then you will be good .
what it does on the muuffs doesnt matter unless your link and sink is incorrect or your throttle is not fully backing off
gopod luck Bennyb
Re: RPM,s
you need to try to get it down to 650 in gear in the water. shifting at 1100 will damage the clutch dog. back your idle speed stop screw out a little to get the rpms, down.
davy mcclelland
Re: RPM,s
Ok,
Will try to reduce the RPM,s in gear......although the manual states it should be 800.
Thanks for the replies...will report back with results.
DAVY
wilde1j
Re: RPM,s
Maybe 800 in neutral, but not in gear. 600 to 650 in gear is where you want to be.
