tidefaneric
Thread starter- Joined
- May 5, 2008
- 4
I recently purchased a 1966 Johnson CD-23E 6hp as a project. It is not running. The carb was nasty so I am rebuilding it. Before I took the carb off I tried starting the engine with some fuel in the cylinders. It would not even kick off. It seems like I am getting good spark. Do I need to check the reed valves? Is there anything else I need to check or replace? The cylinders have good compression and I am replacing the water pump impeller.
