wildmaninal
Thread starter- Joined
- Jul 14, 2007
- 1,897
I was thinking of tapping into the air port on a fuel pump that I have and adding a slip on hose fitting to hook the air pipe off of this little 1959 5.5hp Johnson. Then trying to find a place to mount the fuel pump. I've seen the threads on converting in the past and just read them again. I picked up a pressure tank today for $5 (yes $5), I took the top off of it to inspect the inside it was actually in good shape but of coarse the gasket is bad.
Would I hurt the fuel pump by tapping into it or by possibly drilling the hole a little bigger?
Has anybody tried doing the conversion this way?
Here is an example of what I'm talking about, I was thinking that I might be able to find a smaller fitting then the one shown in the picture. I also had in mind of taking a slip on fitting/pipe out of one of these old motorcycle carbs and seeing if it would fit in the hole.
