Re: Reglassing floor ???
hi twin....welcome to i boats.
the above responces are bang on, ill just add, a few things.
search "core sample" on this forum.......tashas daddy posted a pic of the pvc pipe with teeth. its an brilliant way to find out if the foam is saturated.
the best place to take a core sample is in a inconspicous spot, like under the seats.
make sure you are not approx 4 feet from the transom, or in multiples of four feet from the start of the deck in the bow....
the deck is 4x8 sheets of ply, uasually laid on 4 foot centers, so if you do a core sample on the joint, you will also be going thru the frames...(deck support).
also the bilge area (center of the boat) is uasually void of foam, so taking a core sample in the middle of the boat, will do nothing, you want to be about a foot from the side of the deck, where it joins the gunwhale, (vertical side of the boat).
ok....as far as glassing over the old deck, if the glass has delaminated away from the wood, it needs to be replaced. if you glass over it, you will cause a void, that will trap water, and all your work will actually speed up the rot process.
using a grinder with a grinding disc, cut the fiber glass at the deck /hull joint. make sure not to cut into the hull. if the glass has delambed, (once you cut the deck hull joint) you can just pull up the glass, like a peice of veneer.
as far as matt better than cloth........each has its place.....
matt, or csm (chopped strand matt) is used to add fiberglass to "resin rich" area between the substraight and a cloth type fabric. (this is just one on the reasons for it)
cloth will add stregnth along the longitudinal axis of the cloth...(the direction of the long strands)
.both matt and roving are used on the new deck hull joint...(matt next to the wood), and matt will be fine for the new deck covering........
but i have the feeling, there will be more to do than just, glass the deck...
hope that helps
cheers
oops
