Danny in CO
- Joined
- May 7, 2008
- 21
Hi, I'm new to the forum. I just bought a used 19' boat last weekend. It has an OMC 5.0L Cobra engine/outdrive in it. I took it out last Saturday. It ran a little rough and wouldn't take full throttle without bogging down. Also, the temp never came up. I have ordered the shop manual for this setup but it won't be here until later this week or early next week. So being impatient. I have a few questions.
Yesterday, I changed the plugs which helped it run much smoother and will rev without bogging down. Of course this was in neutral and with the water muff on it. I will time it today if it doesn't rain. Hopefully this will solve the bogging problem.
On the starboard side on the block there is a petcock drain. On the port side is what looks like a temp sender without any "guts" in it and no wires. Is this supposed to be the temp sender or is the sender somewhere else?
On the back there is a 3" or 4" rubber hose coming from the engine to the outdrive that water leaks out of when running with the muff. I assume there should not be leaks here. I assume it should exhaust the water out through the prop. Is this a problem since the water still exhausts or does it need to go through the prop to cool something?
Thanks in advance for your help!
Danny
Danny
