Evinrude4HP
- Joined
- May 7, 2008
- 3
Hi,
Evinrude Model: 44RCUD
S/N: B1374707
New to the forum. I'm a torpedo mechanic, and long time auto mechanic, but this is my first time doing ANY maintenance on an outboard marine motor. I was given this 4hp Evinrude by my father and it seems to be in great shape. I drained and refilled the lower unit with correct oil, and replaced the two sparkplugs which were pretty gunked up from lack of use/maintenance.
After replacing the plugs, the motor starts right up.
Unfortunately, I don't see ANY coolant water peeing from behind the head like with most motors. I plan to pick up the impellar replacement kit today and do the job.
A few questions for you veterans....
1. Where exactly IS the coolant water pee hole on this motor so I can check for clogs?
2. Am I removing the lower unit, or just the two bolts that secure the prop to the lower unit? If its the lower unit, where are those bolts located?
3. Also, is there a fuel filter screen within the carb?
Any help would be GREATLY appreciated.
S/N: B1374707
