Favorite reversing gear
External Combustion
For all of you true inboard owners: What is your favorite reversing gear and why? I am looking for one in the 250 to 300 foot pound range and am just starting the research. Any opinions would help.
JCF350
Re: Favorite reversing gear
Older Units?
Mine has always been Twin-disc.
The only problem I've run into has been the shifter setup. People forget that the lever is supposed to hang loose after engagement.
JCF350
Or are you looking for just a gear changer with no clutch action?
Oh yeah, Behind what? or remote mount?
Shaft speed?
External Combustion
Hopefully I can find one that will bolt up behind a medium speed (1400- 1600) diesel. If not then I can fabricate the clutch/bell housing arraingement.
Either remote or direct control will work.
I have been around several Twin Disc units along with some others, but all of them were pre '70s. I have been told that Screamers almost always had Twin Disc behind them. Any idea about Caterpillar or Cummins? I have in mind using a precombustion chamber engine as they are more flexible in thier fuel requirements.
I have just started looking. I was hoping to avoid pitfalls that someone else has had the misfortune of experiencing. I am hopeful also that I can find an American made unit. Gear reduction of to three to one would be ideal, but I will most likely have to live with what I can find close to this.
Yes, it is for a displacment cruiser needing a little less input from the crew than a steam engine.:rolleyes:
QC
Most Caterpillar gears were/are Twin-disc. A Velvet Drive 71C direct, weighs only 95 lbs. and is capable of 300 lb/ft. input torque. They are cheap too. That's what I'd use.
External Combustion
Thanks fellas! That is what I am looking for. Weight is no problem, though I am pleased at the light weight of the gear. This will allow me to swing a large diameter prop at high efficiency. The large prop has proven to be just the thing for fighting wind. No waterskiing though.:p
JCF350
Well if you wanted to ski you could always add a variable pitch prop.:D
Amazing how much bite you can get with the prop spooled up and then throw some pitch to it (need heavy flywheel though).:)
