Phunahm
Thread starter- Joined
- May 5, 2008
- 39
I have a 86 150XR2 and the alarm works only 90% of the time when I turn the key on, the wire going to horn was checked and is ok,I cleaned all grounds related to the module and the sensors.....If I tap the ignition and turn the engine over w/o starting it sometimes does the self test....other than that it just silent.....does it sound like a module replace in store?....also if I get it to work it sometimes goes into a beep beep beep mode or a continuous beep......if I remove any of the sensors while its beeping it will shut off.......
