Merc 40 With Alarm
merc man
I have a mercury 40 aprox 1992 when ignition turned on you get the first intial beep but some times you get a constant sound even without the engine running by looking at other peoples problems on this site it sounds that constant noise is cooling and beeping is the oil but I am getting no over heating and water coming out plus oil full as this model is an oil injection looked at connections in ignition/gear shift but all ok please can someone help me look in the right place as the noise comes and goes and is driving me nutt's
:confused:
Laddies
Banned
Re: Merc 40 With Alarm
Either the heat sensor is going bad or there is a wiring short to ground.
merc man
Many thanks for replying laddies but would you know where I can find the heat sensor so i can check and where the first place to check for an earth or short .
many thanks
