1992 Alpha I Gen II. I replaced impleller, shift cable, gimbel and all bellows 2 years ago. Everything has been fine since. Was winterized correctly and outdrive was left on over the winter. Just strated, for the first time this spring on, muffs. All was fine for about 5 minutes then I saw small amount of water spraying from the seam of the plate at the top of the drive. The plate is at the very top, held on by 4 bolts and the drive lube dipstick is in the middle of it. I shut down immediatly. Checked oil on dipstick and it did not look milky but did seem to have very small air (?) bubbles in it. I suspect this is not good news. You guys (esspecially Don S) have helped me out in the past. Let me know what you think. Thanks
