55'Fleetwin7.5
- Joined
- May 29, 2007
- 241
I replaced the lower unit on a 1957 18 HP. I could not get the shift likage connected again. As I raised it back up to bolt it together, I first slowly turned the drive shaft and got that inserted... then the copper tube... then I moved the shift lever towards reverse so that it captured the lower shift rod. When I tried to tighten the bolts... they would not tighten. They just kept turning. Are there nuts on the backside that fell off? Any tips to share? Thanks.
