73 115 V4 only 2 cyl. getting spark
rraymer
I have a 1973 115HP V4 evinrude that i am only getting spark on #1 and #4, it has new plugs, wires, new coils, power pack. I have found that if i switch the timing wires i get spark on 2 and 3. Is the timer base bad?:mad:
Any help!!!!!!!!!!!
thanks
HighTrim
Re: 73 115 V4 only 2 cyl. getting spark
Welcome to iboats.
Following is from the CDI troublehsooting matrix.
First check the timer base’s resistance from the #1 to the #3 sensor wire, and from the #2 to the #4 sensor wire. Reading should be 10-20 ohms on each set (or 30-40 ohms for CDI Electronics Blue Timer Bases).
Then check the DVA output from the timer base. A reading of at least 0.5V or more from the #1 to the #3 sensor wire, and from the #2 to the #4 sensor wire (while connected to the pack) is needed to have spark. If the output is low, you may try to reset the air gap between the timer base sensor and the triggering magnet using a sensor gap gauge or by using the following method:
a) Loosen the two mounting screws on the sensors and the nuts located in the epoxy on the outside of the heat shield of the timer base.
b) Slide the sensors in toward the crankshaft until the sensor touches the stop boss located at the base of the sensor mounting area. Tighten the mounting screws.
c) Coat the face of the sensors with machinists bluing or equivalent.
d) Install the flywheel without the key and rotate the flywheel at least one full turn.
e) Remove the flywheel and check to see if the trigging magnet struck the face of the sensors. If it did, back the sensor out approximately 0.005” and repeat steps c, d and e.
f) If the ignition fired, finger tight the nuts on the outside of the heat shield and coat them with RTV.
Joe Reeves
Standing in back of the engine, facing the spark plugs, the cylinders are numbered as follows. Is this how you are calling the cylinder numbers?
2....1
4....3
rraymer
Thanks for your help!
After all this I have determined that there is somthing wrong with the Timer assembly, It is the origanal Timer. Do these go out often? or is it the alighnment of the assembly. Or it could have a cracked wire that is leaking the power off.
There are still a lot of OR'S with this project an not a lot of summer here in MN.
mikesea
I dont think its the timer.Disconnect the big harness plug,remove all plugs and do a spark test.if you have spark on the bad cyl. at that point,your key switch or harness has issues,you will need to jump positive to the starter
