Mercriser will not go in gear
Woody1540@msn.com
When i start my boat i go to put in gear and the motor stalles there is a Ele'pressure switch near the cables is this bad i have a 488 Merc can any buddy help me Thanks
Bt Doctur
Re: Mercriser will not go in gear
More likely is a bad lower shift cable,that switch works coming OUT of gear ,not in.
rodbolt
normaly this is indicative of a bad lower shift cable, while you have it apart carefully inspect the upper shift shaft seal in the exhaust cavity, its a major cause of cable failure in my area.
Don S
The shift interrupt system is designed to make the engine hesitate for a split second to allow the reverse cut dog clutch to release. When the cable is stiff, it holds the SI system engaged long enought to kill the engine before it releases.
Woody1540@msn.com
Is that the roller switch in the middel of the two cabels that moves??
