Installed water gage plug pee hole?
meet
Banned
I get about 12psi on full wot ...should I plug pee hole for more pressure?
gss036
Re: Installed water gage plug pee hole?
No! Where did you tap into the system for water pressure? It should come off the top of the block if it a V-6 motor.
meet
Banned
On head oem tap...but should i block pee hole? for more pressure?
gss036
NO! It will only go up so high and the poppet valve opens, dumping excess water out through the exhaust. 12 psi is all you are supposed to get at WOT/full rpm
gss036
Silvertips installation will not work as well on a V-6. I think that was for a straight6, tower of power. The V-6's have a hole top center in the block for this purpose.
j_martin
It's interesting how everyone is giving their answer and no one but Meet has any idea what the engine is.
Meet, what engine are we talking about?
At any rate, don't plug the tell tale.
John
