AaronWhitt82
Thread starter- Joined
- Sep 22, 2007
- 54
Well onto another problem now after I finally thought I had everything fixed and the whole mess I was having with the carb figured out.
I had my boat out Saturday for the first time this year. She started up great, idled fine and ran absolutely perfect......
I brought my new handheld GPS with me so I could dial in the speedos.
Top speed on the GPS read about 36.8 MPH @ around 3,950 RPM's on the tach.
There was only 3 people aboard the boat including myself and no added ballast.
I also have the stock 13X13 prop on the boat.
I slowed all the way to a dead stop and hammered the throttle and again it would top just under 37MPH and just under 4,000 RPM. I did this several times and it did the same thing every time.
I cannot figure out why it won't go over 4,000??? WOT should be between 4400 - 4800 RPM's
Here are a few things I could think of that might be wrong:
1. Secondaries aren't fully opening in the carb
2. Vacuum leak (I sprayed starting fluid around base gasket and it never slowed the motor)
3. Timing is off
4. Tach is off
All the motor info is in my signature
Any other input would be greatly appreciated
Aaron
3. Timing is off
4. Tach is off
Aaron
