forward is revers and revers is forward
mauimike
I've got a 1981 johnson 60HP that runs real good. I'm useing a johnson shifter. When i put it in fwd the motor is spinning the prop in revers. My manual is on order but i was wondering if you guys could give me your thoughts.
5150abf
Re: forward is revers and revers is forward
More info, how did this come about.
Is the boat new to you?
Have you just worked on it?
Did this problem just siddenly happened?
Tell us how this happened that will help to solve this little mystery.
mauimike
the whole boat is new to me but very used. the shifter and motor are both second hand. while installing everything i didn't notice that the prop was spinning backwords. i was just looking to see that i had both direction and full throttle in what i thought was fwd. needless to say i was quite supprised when i got it the water. when i put the shifter in fwd the lever on the motor moves tward the front of the boat.
mike i believe you have a controller for a 1973-1977 johnny rude. the had a hydro mechanical shift that movement was opposite the current motors.
Randyg123
If you do end up with an old controller like that and so not want it, I may be interested in it.
Or you could just move the motor up to the bow:D Sorry, couldn't resist!
just thought of something, you may have cable crossed at the motor. shift on throttle, throttle on shift.
Chinewalker
The 1973-1977 controllers will work - the differences are at the motor, not the shifter.
If the cables aren't backwards, the likely culprit is someone has swapped in a 1973-1977 lower unit as a replacement. Is the lower unit original to the motor?
- Scott
mauimike
I don't have a lot of info on the motor's history. Is there a serial or model # on the lower unit that i can referance? The shifter is the older white one. I can check the model and serial # on them when I get home.
mauimike
I did verify that the cables are correct
ezeke
The skegs on the mid-seventies lower units go straight down at the rear. The eighties units have skegs that angle back at the rear.
mauimike
the skeg does go straight down. if it is the '73-'77 lower unit is there any way to make it work?
Dhadley
Yes. All you need is the linkage off a powerhead of the same vintage as the lower unit.
mauimike
I really don't know much about these lower ends. What linkage are you takling about?
rolmops
Could it be a left handed propeller?
mauimike
no it is a right hand prop. A left hand prop would be nice if i could find one
rolmops
You might be on to something.
Possibly your engine was part of a twin setup, which would mean that you need a left handed prop.
mauimike
i thought that might be the case but i haven't been able to find a left handed prop anywhere. Do they make them for this motor?
jay_merrill
Did OMC even make a left had rotation gearbox for a 60hp motor? I don't know for sure but my guess would be that they didn't.
