1972 Johnson Power Pack
FFWFD12
Hi! I recently bought a 1972 100hp johnson outboard(for $25 bucks) that needs a power pack. I believe the one on it now is an aftermarket one, it says ronken on it and the number is 50A78105K01, it also has IMF 500 DC, and 8442. The model number on the motor is 100ESL72R, and the serial number is J3699383. Does anyone know what the replacement numbers of the power packs that will fit this motor are? Also I have found some that supposedly fit this motor but they look completely different, and without the numbers I don't know if they will fit. Would the fact that they look different matter? Thanks in advance!:confused:
npd4432
Re: 1972 Johnson Power Pack
BRP part #0384522 pulse pack assembly. $483.00 list price ouch.
al27023
I believe there is a sierra part, search using number above, that requires some wiring mods. About $200 - installed one on 72 Evinrude 100. Apparently called a battery cd system uses battery voltage to run - you need a good battery and charging system to keep it running.
Good luck.
FFWFD12
Hi! The guy I bought the motor from said it needed a power pack, I'm guessing the pulse pack is the same thing as a power pack, is that right? If not what is a power pack, i've seen some power packs supposedly for this motor but they look completely different than the pulse packs. Could someone explain? Thanks for all the replies!
