billynjuls
Thread starter- Joined
- Jun 21, 2005
- 35
I recently purchased a boat that had a 2002 Mercury 50 HP 4-cyl 4-stroke EFI motor. I purchased it from an older gentlemen and it had been sitting for about 2 years. The cowling was always installed and the motor looks brand new. I doubt if it has 10 hours on it. It cranks strong with good spark, but will not start. When I choke it, the fuel enrichment valve (choke) does not click. It has two yellow w/black wires going to it. There is also 2 yellow w/black wires coming from under the flywheel. When I check for voltage a little ways after the ignition switch I have 12 volts for the choke wire (yellow w/black), but when I check it at the choke itself I have 0. I can't figure out where I am losing power at. The wires running down the bulkhead going into the engine are in a hardened shield so I doubt there is a broken wire in there. Should it be able to start without the choke working or is it that difficult on a 4-stroke EFI to start without it? Thanks for any help.
Billy
Billy
