txbandit44
- Joined
- May 11, 2008
- 182
OK bought a boat from my boss for 50 bucks. Its a 16ft 72 doggett with a
65ESL-72S. I have justa few questions.
First some motor history. It hasnt been fired up in about 11 yrs. He said that the last time he has the boat in the water and running the lower unit locked up and threw him from the boat. He said that he could still start and run the motor but it would abroptly stop if shifted to forward and reverse.
I tried to just turn the motor by hand with the plugs out and it would not move but about an inch in either direction. Today i tried and i could turn it failry easy and I could make a full revolution. I will be following the info in the FAQ about reviing and old motor. I am pretty sure the lower unit is toast. I can only turn the prop about3/4 turn clock wise or counter clockwise. I also noticed that the prop was turning as i turned the motor, but did not seem to have the same rotation speed. I assume there has to be some reduction in the lower unit gearing.
Questions are
Where can I get a Factory service manual for this? Will it cover the lower unit as well?
HOw or where would I go to find out what lower units will fit my application?
I mean i know I have a 72 hydroelectric shift for a 65hp but what else used the same unit?
How hard is it to rebuild a lower unit your self? I am great with automotive and have a very mechanical mind. But this will be my first rodeo on an outboard.
Before I get crazy with trying to fix this thing up. I want to make sure the motor will run. since the lower unit is mostlikly toast and seems to be locked in a gear with the motor. Can I stil start this thing? IF I have trouble starting the motor with the lower unit attached. Can I start it without the lower unit? Im not looking to run the motor just hear it fire up maybe run for a few seconds. Just enough to give me hope and the courage to open my check book for parts.
Also does anyo one know what the "S" at the end of the model # means?
Thanks for reading I hope this isnt a lost cause. well not a total loss I did get a $1100 80# minn kota with the boat so I guess im $1050 ahead at this point
Questions are
