Re: Basic fiberglass repair
It's not a cosmetic repair so it should be pretty easy. There are thickend epoxies that are designed for this type of repair. Interlux makes one, I'm sure there are others.
You should grind down the area to be repaired to get to the underlying fiberglass. Roughen this up with a 60 grit sandpaper, wipe it down with acetone and apply the epoxy. You can use an old playing card (waxed paper type) taped into place to hold the epoxy till it cures. Make it nice and thick. If the repair area is large you might want to add some fiberglass cloth to reinforce it.
Once it's cured you should pre-drill your holes all the way through and use bolts instead of screws. Put large washers on the backside (as large as you can get in there) or make a backing plate from some thin aluminum stock. This helps spread the load over a larger area.
