Jeff Salinas
- Joined
- Apr 28, 2008
- 23
Hello everyone,
I previously had a 9 x 9 prop on a 15HP Merc on a 11' tunnel inflatable. I felt the prop did have some good bite and my max speed(via GPS) was 21.9 mph. I then felt I wanted to go with another prop mith more pitch. I purchased a Quicksilver Mercury 9 x 10.5. On the same boat, it would rev out alot right from the start. It took a long time for it to finally catch. My top speed dramatically reduced, which I thought was normal because this time the boat was carrying myself and my dive buddy. We were only freediving, so no tanks and extra ballast.
Last weekend I acquired another boat; 13' 3" Tunnel Inflatable(DUX Inflatables). I mounted the same motor and new prop;9 x 10.5. Last night I took it out for a test ride in the bay. It would not go past 5mph without trying to over rev the motor. As soon as I would throttle up the motor, it would just rev up and I would get absolutely no bite. My trim is set to zero. Here is a picture of how it is set up;
Any thoughts? Now I'm thinking or hoping that the new prop is defective and I'm just turning the hub thru the prop. I won't know till I mark the prop and rerun. but first I'm going to remount the original prop; 9 x 9 and see if I can at least go past 5mph and get somewhat of a bite past half throttle. I'm then going to put back the 9 x 10.5 prop, but this time mark it to see if there is any slipping thru the hub. I'm going to run these test this afternoon after work. And I just want to know anyones thoughts on this matter, as I'm getting really anxious this morning and can't wait to run my test. I will report back with my findings.
Thank you,
Jeff
Thank you,
Jeff
