carb overflowing
terrylee
I have a 1993 mariah with a 4.3 v-6 in it the mercarb is letting gas flow into the manifold it is running in at the bottom of the carb can that power valve go bad and let gas just pour into the intake mahifold.
Thanks
Terry
Coors
Re: carb overflowing
Rebuild it, or have it re-built. Float is stuck.
terrylee
I put a new needle and seat in it I thought that was the problem also,I also put a new gasket on it.
thanks
Terry
Coors
Total re build time; the gunk carb cleaner is expensive.
But cheaper than the shop.
terrylee
So I should buy a complete rebuild kit fir it and do a complete rebuild???
Thanks
Terry
terrylee
I was looking at carb kits online the only thing I have not put new in it is the power jet thats why i was wondering if it could get bad and let gas pour thru the jets at the bottom of the throttle body.
Thanks
Terry
terrylee
I was wondering could the float need to be adjusted to stop the problem
Thanks
Terry
Ayuh,...... That apart of the Rebuilding process......
The Float could also be Too Heavy.....
