JT!
Thread starter- Joined
- May 19, 2008
- 260
i recently acquired 2 motors, one of them is a 50r79c
i have the motor on a workhorse, and am looking to reassemble the carbs, which apparently have been cleaned up. the reeds appear clean (the motor was on the ground with the cover off, and no carbs)
my problems:
1) the big red connector has nothing connected to it.
2) it should be a pull start but the cord and spring assembly are missing
3) it came with an electric starter in a box, and the bracket fits, can i use it?
4) can i build an independent circuit myself for the starter, if the motor doesn't allow?
5) should the motor be able to be started on a bench without any special connections? a quick hand-turn of the flywheel didnt produce a spark with the plugs taken out and contacted to chassis.
6) i have the service manual, but cant figure out the torque for the head bolts.
7) is the head gasket metal or paper? will i damage it by inspecting cylinders?
8) why would it be listed as a 'rope' model, but have a starter in it? is this normal?
9) is it safe to wind a rope around the flywheel and pull? will i lose fingers?
-my main worry is the red connector, where does it go?
-attached below is the picture of the way the motor was when i bought it.
thank you in advance
JT, in Montreal
my problems:
JT, in Montreal
