What to resin
KnottyBuoyz
Re: What to resin
You'll need to radius those corners somehow. Traditional method is to create a fillet with thickened epoxy and filler (chopped mat, colloidal silica, wood flour etc.) This allows the glass to make a gradual transition from one surface to the other.
Here's a good illustration of fillets in a S&G project.
The theory behind the practice is that fiberglass is strongest when the fibers in the material are kept straight. Bends, especially sharp bends weaken the fibers and they'll eventually fail. Most woven fabrics will have poorer performance structurally than biaxial fabrics, which have all the layers of glass oriented in straight lines overlying each other and running at various degrees from one another.
This is why woven roving is a poor choice for structural use. It is often used in older boats and older methods but relies, IMHO, too much on the structural qualities of the resins used. Similarily mat provides little, if any, structural benefit to a fiberglass lay up. What it does do is provide a medium for a heavy fabric to adhere better to a core, such as plywood, by filling in the voids between the weft and weave of the fabric. It is also most commonly used on top of a woven fabric to help fill in the same voids so that the pattern of the underlying fabric doesn't "print through" quite as much.
Good luck with your project.
zach103
Re: What to resin
i went with the construction adhesive.. mine looks so messy compared to yours
zach103
Re: What to resin
little messy but it was my first time lol.. now because i used the adhesive do i have to put a layer of resin over that or can i just put the mat on now. the bottom where its all globbed up on the side is just extra thats why its globbed up
ondarvr
Re: What to resin
Resin won't stick well to the adhesive (if at all), so if you plan on using it, the bead in the radius needs to be small and uniform with no adhesive extending away from the radius and on the wood. You can use some filler and make putty out of the resin easily, at least the resin will bond to that, so if you get it all over the wood it won't be as big of a problem.
salty87
Re: What to resin
the mat needs resin under it, very much like a stamp for mailing something. you can try to put the stamp down and lick over the top but it will stick alot better if you wet the under side first.
also, all of the bumps and areas where there are ridges from the leftover glue will either need to be wiped flat when its wet or sanded down before glassing. you won't be able to get the mat to bend over it, air will get trapped under. its alot easier to prep the area right than to go back and grind out bad spots and re-glass em. you'll have to do the same if you use thickened resin too.
Robj
Re: What to resin
I wouldn't use that construction adhesive at all. Use peanut butter, you know resin will stick to it.
Have a great day,
Rob.
zach103
Re: What to resin
so no adhesive .. sounds good. .. now im not really sure what you mean by peanut butter?
jameskb2
Re: What to resin
"peanut butter" is a mixture of thickened resin. You would use it instead of your construction adhesive. You thicken the resin with a medium of wood flour, micro balloons, glass fibers or the like.
Search the forum for peanut butter.
You fillet the peanut butter into the corners like you did your construction adhesive. "Tip": Round the corners of a 1 or 2 inch putty knife, or use a cedar shim (like for setting doors or windows level) into a "tongue depressor" shape. A nice round tip. Use that for spreading or smoothing the peanut butter mixture into the corners for a nice even fillet.
And, BTW, I've yet to lay any 'glass myself. I'm still reading and learning here! :)
KnottyBuoyz
Re: What to resin
Peanut Butter = Epoxy resin & Wood flour
Wood Flour does not equal Saw Dust
Wood flour is cheap. Other fillers have been mentioned and most have specific properties making them useful for various applications.
Here's a pretty good looking peanut butter fillet
Radius is about 1 inch.
ondarvr
Re: What to resin
Since you're using polyeser resin use that, not epoxy, but it's the same process.
zach103
Re: What to resin
im guessing you can find this wood flour at any home depot or lowes right? .. i started work on the template today cuz it ended up being crappy..
KnottyBuoyz
Re: What to resin
Don't think you'll find woodflour at Lowes or HD more likely places like Boat Builder Central or Jamestown Distributors or other stores that sell epoxy and resins. I don't think Iboats carries that kind of stuff but I haven't looked.
zach103
Re: What to resin
i found some.. they sell it in either 1 quart or 1/2 gallon.. now how do i determine the amount im going to need?
zach103
Re: What to resin
yah i ordered the name for my boat from iboats and they set me this yellow plastic peice to run over the name to get the air bubbles out.. well i was done with it. so i cut it so the edges were round and fit to make that even spread
Coors
Re: What to resin
A cd disc works good for the fillet, so does a spoon.
