Spark Plug Gap for Yamaha 9.9 4 cycle
yamaha chris
Does anyone Know or Know where I could find the spark plug gap spec. for a 99 Yamaha 9.9 High Thrust 4 stroke outboard.
Thanks
CatTwentyTwo
Re: Spark Plug Gap for Yamaha 9.9 4 cycle
For what it's worth, I have the Yamaha owner's manual and service manual for a 95 T9.9. The owner's manual says .020 to .024, the service manual says to gap the plugs at .024 to .028.
yamaha chris
Thanks Ryoung
I would think they would be the same.
Thanks
Chris
BruceAML
You need to post the complete model number from the data plate. The gap can be found in the genuine Yamaha owner's manual or the genuine Yamaha service manual. If your motor uses an NGK CR6HS spark plug, the gap is .024. You need to torque the spark plug when it is installed.
