A freak thing has happened to a buddy of mine (not me) who has an engine he thinks is blown up. He has a 2007 Mercruiser, 350 Mag that was winterized by the dealer he bought it from. He took it home and stored it. This Spring he put the plugs back in the engine. Hooked up a hose and ears to the lower unit and started it up. It purred nice but it is not clear whether he did not let it run long enough to know if water was circulating through. I'm also not sure if he turned it over before the water was running or he turned it on after. He said he ran it 2 or 3 minutes. ( I always make sure I see water circulating back out the engine and then wait for warm water to show up so I know the thermostat is working.) He put the boat in the water and 20 minutes later the engine burned up. It started smoking profusely. It doesn't sound like there was any water in the block according to the dealer. The temp guage never shown more than 170 degrees and no alarm sounded when he had it running which makes sense if there was no water in the engine. The paint on the engine even got crispy and fell off. It won't start now. The dealership he bought it from made a comment to him that he could see no reason they would be able to warranty the engine (he has a 2 year warranty on it). Does that sound reasonable that a boat less than a year old that was winterized by a certified merc service center couldn't be warranteed? I would guess the impeller or water pump didn't function sense there was no water in the engine. I would think the hose preasure would have pushed a little water in when he had the ears on wouldn't it?? I know just enough to be dangerous but was hoping some of you guys who are much smarter than me can shed some light on what may have happened and if you think he has a leg to stand on regarding the warranty issue. Understandably, he is pretty sick about it.
