Mercruiser power steering
Status
Not open for further replies.
OC Rider
I have a Mercruiser 4.3 and i changed the oil last week and want to add power steering fluid this weekend but not sure what to use. Can i get some help. Thanks.
Fishermark
Re: Mercruiser power steering
I don't know what you have (other than a Mercruiser 4.3) - but if you are just needing to add power steering fluid to your power steering pump.... then you use power steering fluid. ;)
OC Rider
I figured it's power steering fluid but what kind. I've seen some threads showing ATF type F, Dexron, Dexron ll and i even saw one that said to use 10-30 motor oil.
Ayuh,.....
P/Steering systems,+ Trim systems are the simplest of Hyd. systems,....
They'll run Just Fine on about Any Oil you pour into them,.....
That Said,.....
Just match the Color of what's in it Now.....
If it's Red,.... Use ATF.... Any of them.....
If it's Brown,..... Use Motor oil.......
Status
