on land i did the cable adjustment as per the oem manual. everything seem to work find, lock in both gears. put on the muffs and was able to shift from forward to reverse. i just got back from the lake and it will not go gear to neutral from both forward or reverse.
from reading this sounds like the interrupt switch. before the adjustment i check with a meter and it switch worked.
i guess my question is: what could be out of adjustment? i thought i did the adjustment right. what should i adjust? the shift (upper) cable the front plastic piece is all the way back (no threads showing) and the back plastic barrel of the upper cable is about 5 turns out. the drive cable is adjusted to the 6" hole to hole. is there an adjustment that i should make at by the shifter?
how should the interrupt switch act? when shifting from neutral to forward should it rotate out of the pocket for a second and then back in to the pocket?
thank in advance
thank in advance
