cmblackburn
Thread starter- Joined
- May 25, 2008
- 8
I have a 1993 Force 70 that is not charging my battery. I am using a fluke DMM to read my readings. I have measured the resistance of my charging coil on the stator and according to the clymer manual it reads fine, its reading less than 1 ohm. I read the AC volts coming off the coil and its only reading between 6 and 7 Volts AC. I checked the DC coming off the rectifier and its reading is only 12.5 Volts DC when the motor is running and 12.9 when I turn it off. I am leaning towards the stator being bad but wanted to get some expert advice. Thanks for any replies.
Also what is the easiest way to get the flywheel nut off?
Thanks
Chris
Thanks
Chris
