My 1957 fd-11k 18hp still will not start. Here is where it is at:
1. New coils
2. New condensers
3. New points (could be the problem, not holding gap at .024)
4. New plugs gapped at .030 (Champion 4 series)
5. Rebuilt pressure tank
6. All new gas hose on pressure tank and engine
The motor pulls through and backfired a couple of times. Checked for spark and have spark, checked gas and have fuel to the carb, checked that the correct plug wire is on the correct cylinder. Pulled the plugs and dried them off after about 12 to 15 pulls. Tried the following:
1. Throttle at "Start", choke on (backfire puff of smoke, then nothing for a while followed by gas leaking from carb, assume flooded)
2. After dry out of plugs and tried same without choke, no backfire, no smoke
3. Choke on, motor in gear, half throttle, nothing
4. Same as #3 with full throttle, nothing
5. Same as #3 or #4 without choke, nothing
Also noticed that the "fast" and "slow" speed settings seem to do nothing, and may not be working at all. The knobs turn but the springs do not move. I also noticed through the flywheel window when re-checking the points that they were not holding a consistent gap, were anywhere from .019 to .028, not sure the window is always in the exact spot, or if this is a problem with the points or how they were installed.
Anybody with any suggestions before I end up taking it to a shop?
1. New coils
2. New condensers
