MASTER Brian
Thread starter- Joined
- Mar 26, 2006
- 738
Re: determining which prop to buy
Dhadley, does it look like I could still raise the motor? Did you see the pictures and if so, were they clear enough as far as the mounts? I think I mispoke on my first message regarding motor height, as the motor is definately sitting higher on the transom. I'll try to get another picture.
Is there a formula to tell if you can raise the motor more? You speak of venting, but I'm not sure I totally understand it. Are you speaking of venting at the prop, which I understand deals with hole shot, or are you speaking of venting when the boat is trimmed up at WOT?
I get real uneasy, when I get to the top of the trim range, as I don't know how accurate my gauge is (I know some don't even use gauges and can tell by feel) and I don't want to hurt anything. I just don't know how to tell when I'm too high on the trim at WOT. Is it possible to hurt the motor, if I overtrim, or if I'm just easing into it, will it just start to give me a warning??
I also understand that the Raker is a vented prop.
I hope I'm not repeating myself/my questions, but I need and want to understand fully. Am I better off and will I get the same results by adding a jack plate? If so, what is a good one to get for a reasonable price? Or am I better off getting a different prop? Does dropping a pitch raise the rpm's across the whole spectrum or just the higher speeds? The feeling I'm getting is like when your car is stuck in some mud and you hit the gass and the wheels won't turn, so the motor just boggs down.
K.P., thanks for the compliments, but the boat pictured isn't my boat, it's the same boat with a different motor and Troller. It's just what I had a handy picture of at the time.
Dhadley, I am also curious, who you recommend to rework my Raker. I have a few small nicks and scratches I'd like taken out. I don't think they hinder anything, but I want it nice. Maybe I'll include a picture as well. Most where there when I bought the boat, but these mud bottom lakes by me suck for having stuff in them, then to control errosion, they keep adding rocks right next to all the ramps.
I'll look into the Turbo Lighting's as well. I'm glad you mention not to but the Raker's reworked, because I did see one or two on Ebay that had been.
